Disable Vision Position System?
Great Neck NY
Hey Guys, I heard that some people turn off the Vision Position System when flying over water.. I fly often over the ocean is this common practice.. Havn't flown over water yet with my P3P so before I do I wanted to check with you guys.. thanks!!!!
I always turn it off when flying outdoors. It's most useful for indoor flights.
Can someone confirm this for me, I spoke to two different DJI techs this morning on my vision position system(VPS) issue when flying indoors, the first tech said the VPS only work on "F" mode....The second one said it should work on "A" mode because the "P and F" mode have GPS enabled and if I'm getting any drifting on "A" mode flying indoors I should send it in for inspection or return it to BB where I bought it....
The only thing that is bothering me, I have done some testing on my own like placing file on top of the aircraft while it is in "P" mode, it works in "P" mode when it's not getting any GPS signal and the manual also stated you of to be in "P" mode for the VPS to work
drone-jpg.33835
robvalduga
