- Joined
- May 27, 2018
- Messages
- 4
- Reaction score
- 1
- Age
- 56
Hello group and thanks for any help in advance. I'll preface the following with fact that I've searched for similar issues in the forums and have not found same thing, so I apologize if this is an old issue and I missed it. I have a few UAVs but my quick deploy Phantom P4 is usually along for any ride. I had used it multiple times this week without any issue and with the normally beautiful photo quality. When I downloaded the photos pre and post using the DNG cleaner, I noted a loss of quality to the final four photos I had taken yesterday. 6 were fine and 4 had the attached defects. The drone was not crashed, hard landed or otherwise stored as I had seen questioned in another thread regarding white or yellow spots. It was flying and handling fine, camera responding normally, etc. EVERY photo since those 4 that I've taken as a test image in sunlight and shade has produced the same defects. Has anyone else seen this or experienced anything similar? I did open the camera and check all cables from the UAV to the processor and nothing was apart or loose. The camera is a DJI replacement that I obtained last October following a camera disconnect from the P4 that couldn't be resolved any other way than through a replacement. It has worked flawlessly until yesterday. I surmise that the processor may have failed, but was hoping for an easier fix than acquiring a new one.
I should also mentioned I tried two other SD cards and also have not recently updated firmware.
Again, any help is GREATLY appreciated.
Kevin
Kevin
