DBS Mod first results
Adirondacks, NY, USA
Here is a collage of two flights from my deck toward the lake. Before DBS last week the app disconnected and I lost video (two attempts). Had RC. Issued RTH command via RC both times. After DBS today I flew out till I got worried about the battery getting me home (windy). 12,103 ft. (no obstructions). Signal was still real strong when I turned back. Landed with 37% battery.
Reactions: Matts175 and angus
Excellent! I haven't tried my P3S for really long distance but the DBS mod definitely increased my range.
Not really in this case. Here is the video. I sped it up so the yaw motions are more jerky than usual. I need to work on that.
Thats awesome, ive only managed to get 6144 ft so far
How did you managae to 1200 ft?
Im really interested
I got out to 14,000 ft on a later run. I added the DBS Itelite antenna to my RC. It's a wide open unobstructed view out over the lake
i have dbs my maximum is 6144ft lol
I've not tried it anywhere else yet. Could be that my situation is optimum in almost every way. I have no houses near mine so my controller won't get much interference (I should try turning off my own router to see if I get further ;) ) It is well above any houses on the way to the lake and then it's over open water. No line of site obstructions whatsoever.
I should mention that the video downlink gets choppy if I try to do pans. This makes it hard to get smooth pans because I can't see exactly what I'm getting. I don't know if hardware Acceleration setting has anything to do with it.
Reactions: Dazzauk
do you notice at all you pahntom drifts ever so slightly after letting oof the forward stick?
After watching your video i notices a couple of times it looked like you bird was moving on its own to the left, only ever so slightly but mine also seems to do this at a big distance from me
Not sure where in which video. But I'll have to look the next time I launch it. Bear in mind that I think there was a pretty good breeze on those long flights. Also I've noticed myself accidentally applying side pressure on the stick at times.
Reactions: Dazzauk
Very, very good. I've made it to over 16000' once, but that's with amps too. Going over a big lake has to help a lot. What FW are you on?
I think it's 1.5.70 or somesuch. I did a downgrade to a recommended good version A little while ago .
Good work. I've only gone 6400 DBS and boosters. I had max bars still. Any further and I'm in a national forest which I avoid.
That was a good FW 1.5.7, wish I stayed there.
Nice job that was a nice flight. Great song for the video too. I'm curious as to what software did you use to edit and add the music?
Thanks.
My editing right now is painful. I used final cut express on an early 2008 Mac. Everything needs to be rendered and adds a lot of wait time even for these short vids. And also takes time to encode while writing the file.
Folks, here is a short video from one of my RTH on one of my long DBS test flights. I really like how this came out. The music helps the mesmerizing mood. :)
Reactions: Keeney101
I just installed the DBS on my P3S and had great results! Initially I topped out at about 6500 ft but once I increased my altitude from 250 ft to 400 ft I was able to keep going out to 9150 ft! Super cool mod, 2 thumbs up!
thedrinklabsus
