Damage MOV file
Hallo plese help.
Today I was flying. I forgot to stop recording video. The first one turned off the battery. The MOV video format can not be started. It's damaged. Is there a program or a way to save the video. Thank you.
Put the card back in the drone, power it back back up and see if it finishes writing. I've heard this works, I've personally never had to do it though.
It does not work. Now it can not be copied back to the PC. Thank you for your help. Fortunately, only a test flight. Mistakes are learning.
Just copy it back from your pc to the card. Writing or finalising the file will still, hopefully, be completed, as ryantrax has suggested.
Yeah that might work, if hasn't started his Phantom since he pulled out the card and of coarse (now), if he copies it from the PC to his SD card.
Rod
dlr11164
