P3 Firmware Crazy beeping. Help asap
t2adze said:
i turned it off. w @ something was wrong with the update. TXT says update failed. nice @ . , @
what should i do now?[/QUOTEA]
I started updating the fw. @ A A. AAAA. @ ADA *.
Put it @ on formatted SD card. @@
It did < @@ the update. tt a. and red. It took over 10 wAaaaeS eAeWRa..r~ a, , @ 4,. And after @#A @ @£ 4 _ a a v @ , 2 . AKU A. started A Aaaa a something like this.
Its still doing it now. i* £ a.
That was a scare for a second!)) Happy it worked out for you also!
Procharged97 much thanks for the support!
No problem I'm glad you got it working!! Now you need to go out and enjoy it!
I think i got it fixed.
Turned it on. With sd card in it. With freshly copied FW 1.8 on it.
Turned it on and left it like that.
It was loud alarming for 6 minutes after which stopped and did an upgrade of FW like usuall and it took it 2-3mins after.
So i think everything is correct now? Check the screnshot
Yes that looks correct!
