P3 Firmware Crazy beeping. Help asap
Discussion in 'Firmware' started by t2adze, Apr 7, 2016.
  1. t2adze
    I started updating the fw.
    Put it on formatted SD card.
    It did start the update. Green and red. It took over 10 minutes. And after it started something like this.
    Its still doing it now.
    Is this normal? Its still going on.
  2. t2adze
    i turned it off. obviously something was wrong with the update. TXT says update failed.
    what should i do now?
  3. Procharged97
    Canterbury, CT
    Mine started beeping when it got to 40% and kept doing until it was done. I literally just finished my FW update....took 18min...after it was done it beeped until I restarted the Phantom now it's good. I have the P3S but I assume they are all similar when it comes to FW updates
  4. Procharged97
    Canterbury, CT
    Just search on here "Firmware update failed".... There is a lot of help on here. You can always check out YouTube. I will see what I can find for you.
  5. Procharged97
    Canterbury, CT
    . Check this one out
    t2adze likes this.
  6. t2adze
    I reformatted the SD card
    Copied firmware (redownloaded)
    Put it in the drone.
    And look what it does now
  7. Procharged97
    Canterbury, CT
    This one got good reviews. I hope one of these help you.
    t2adze likes this.
  8. Procharged97
    Canterbury, CT
    The first FW update I did failed awhile back. After reloading it it sounded like a very loud alarm clock for 22min. I set it in garage and walked away. Was fine after. Are trying to update it again with it beeping loud???. If so just let it sound off for 15-20min
    t2adze likes this.
  9. t2adze
    So did you check my last video? is that what it was?
  10. Procharged97
    Canterbury, CT
    Yes that's what mine sound like when it failed. Really loud??
    t2adze likes this.
  11. t2adze
    Very loud. it's night here. I can't do it now. Will have to try tomorrow.
    So tomorrow, should i insert SD card with firmware in the drone and wait for beeps to go away or without sd card?
  12. Procharged97
    Canterbury, CT
    Reformat card. Load update on card. put card in and start update. Let it beep for 15-20 it will stop. Let me know how you make out
    t2adze likes this.
  13. t2adze
    Will do! I hope all willbe fine. Thanks a lot!
    p.s.
    Maybe i should try putting 1.7 fw update on the card?
  14. Procharged97
    Canterbury, CT
    I'm sure all will work out. If the new one fails again it would be worth a shot to try the 1.7
    t2adze likes this.
  15. hionbusa
    My p3pro does the exact same thing .
  16. t2adze
    I think i got it fixed.
    Turned it on. With sd card in it. With freshly copied FW 1.8 on it.
    Turned it on and left it like that.
    It was loud alarming for 6 minutes after which stopped and did an upgrade of FW like usuall and it took it 2-3mins after.
    So i think everything is correct now? Check the screnshot
  17. hionbusa
    Same here . Just turned it on and left it inside my car in the garage ;)
    That was a noisy beep
    t2adze likes this.
  18. t2adze
    That was a scare for a second!)) Happy it worked out for you also!
    Procharged97 much thanks for the support!
  19. captainmilehigh
    Northeast Florida
    Updated my Phantom Standard yesterday, and at 53% it started beeping and the gimbal/camera started going bonkers. Was a bit worried and ALMOST shut it down. But after about 10 minutes of watching it go nuts it finally got past the 53% and only beeped and buzzed for the next 8 minutes or so. Finally updated successfully and all is well. Maybe dji should include a disclaimer or notice about what might happen during the update.........AND......what to do if it fails. Just a suggestion dji. Also, thanks to all you fellow pilots for your info on this problem. Good Luck !!
    t2adze likes this.
  20. deval
    Y, @ aa a a a. a@. a. a. a. a. Fwa f, %. @ Awa @@@ @*. . Di. r. 2. aa. a ,2 aaaa
Similar Threads - Crazy beeping Help Forum Date
Help Please Gimbal Repair Crazy Pro/Adv Discussion Dec 29, 2017
CRAZY FOOTAGE THAT I CAME ACROSS ~ Enjoy! General Discussion Nov 25, 2017
Professional Gimble going crazy Phantom 3 Help Oct 8, 2017
Any ideas .... Gimble going crazy Phantom 4K Oct 5, 2017
Lose video and Gimbal goes crazy Phantom 4 Help Oct 3, 2017
