- Joined
- Jan 13, 2016
- Messages
- 891
- Reaction score
- 356
The overall better suggestion would be to learn to read the flight log data. The .txt flight log file will need converted to a .csv file. The current converter that is best for this now has fee's attached in order to convert them. However, there should be a New FREE one ready for use in the next 7-10 days hopefully. Stay tuned for that news.
Excellent point "Frank" as to applying the "flight log data" as part of the overall maintenance plan!
Just wanted to point out there will always be heat variances in the motors. Each motor will turn a different rpm based on flight pitch & roll alone. The temps can be confusing when the a/c has a heavy side wind while in route.
My point of checking by touch is – if one or more motor frames has a very noticeable difference as to touch it warrants further investigation as to winding insulating integrity. By noticeable difference I mean hot versus warm since these rotating frames don’t get beyond the warm point to the touch after flying.
You are correct that by touching the frames of the motors there will be variances as to temp due to unequal loading during flight with the throttle, wind directions etc. (slight differences) - all valid points to consider. It will be difficult also to determine internal winding temps this way without doing an actual temperature measurement at the windings. You may feel a slight difference when touching closer the bottom of the motor frame – however the rotating housings/frames won’t give a very accurate reading as to temps since they feel just “warm” to the touch due to internal clearances and an open frame design, even using IR spot thermometers that only measure surface temps wouldn’t show as being high or very accurate at the frames.
With regard to motor temperatures; it really is imperative to know the motor temp rise and max allowable temp for the motor windings regardless of variances in temperature between motors or flight conditions etc. Since a motors’ winding insulation is the true determining factor with regard to its life span it is important to realize the temp rise with respect to windings and insulation value.
(A Motors temperature rise is based on the change of temperature within the motor when operated at full load or if you like full throttle over a specific period of time that allows for motor temp to settle/remain steady + using a standard of 40’c ambient air temp. The difference between the motors starting temp and its final increased/steady temp in that ambient temp = motors temp rise – winding temperature. An allowance of 10’c is added to the calculated rise to take into effect the internal windings hot spot).
I have no idea what the temp rise is for these motors but I did read on a DJI forum somewhere the max safe operating temp for the 960kv motor is 51’c (seems a little low). So by doing a little reverse calculation we could estimate the motor temp rise. If we applied the standard used for air ambient temp at 40’c, and by using that estimated max operating temp of 51’c (assuming that is the steady final increase in temp we see during say a "static testing") we would subtract 40’c from that 51’c for a total of 11’c motor temp rise. We then add a 10’c variance/allowance for "hot spot" internal windings temp that gives us our final allowable motor temp rise at 21’c (as stated, seems low).
e.g. If you are flying with a 25’c air ambient temp and the rise is calculated at 21’c our operating temp for the motor including the estimated temp rise could be in the *46’c range (5’c lower than the calculated/estimated max allowable safe operating motor temp suggested by someone at that 51’c). Doubtful when flying with the cooling from the props and the motors ability to dissipate heat with the style of frame it has (open) we would even reach that temp.
*other variables to include would be amount of time operating at full load/throttle – not very likely those internal temps are met with a 20 minute flight time with prop down draft/wash for cooling and combined with an open frame motor. It’s the down time when taking a break during fly times, or changing batteries when the internal temps of the windings can be adversely affected due to no cooling effect from the props and sitting idle.
“Rule of thumb”; the life (L10) of motor winding insulation (i.e. motor) will be cut in half for every 10’C of operation above the rated insulation temperature – conversely, if motor is operated at 10’c or more below the rated hot spot temp, insulation life can be doubled (when calculating the unused capacity of 10’c).
I noticed on a DJI forum they mentioned the life (L10) of these motors was around 200 hours. That is ridiculously low for them IMO and must be a mistake on reporting of same – I think perhaps they may have meant the life of the bearing and even that is low for the bearing. The neodymium/Iron used in the magnets don’t even feel any negative effect till around the 80’c + mark and we won’t be flying anyway with temps that high since all the lubricant will be long gone from the bearings. DJI”s latest motors on the P3 use double layer, single wire stator, this also allows for quicker heat dissipation from the motor windings – hence, a further extension of windings insulation integrity and life well beyond that 200 hours I read about. That had to be a mistake!
