Jim,
nice write-up.
my procedure:
i use 800 grit sand paper to slightly sand the shaft, then i cut diagonally into the shaft with a 412 dremmel, just about 1/16 deep.
the reason i do that is once pematex dries it sits right in that cut inside the shaft
i put little red permatex on the shaft and put the drum back on and heat it to 400C to "sink in".
then i tighten it with C clamp for 48 hours.
after that i put everything back together and make final adjustments so the camera is at the perfect 90 degree angle.
i take the camera back off and cut into the shaft/drum with the same 412 dremmel about 1/4 inch wide and 1/16 inch deep.
i clean the cut with fiber cleaner and pour two layers of 1.5mm bondic into the shaft/drum cut and heal with UV light for couple seconds.
that's it.
it takes me about 20-30 minutes of handling time, besides the 48 hour wait for permatex to completely cure.
always have plenty of yaw arms, main boards, P and R sensor boards and cables so i can pretty much have
about 8-15 gimbals available at any time.
