couple of things please
Out flying the p2 and cant help me thinking i want some more forward flight speed,coming from a cheerson cx20 i could change the angle max settings and was wondering if any can be altered on the p2,one other thing i was asked today does the p3 std have the same vido feed quality as ours and has anyone modded the handset to fit the wifi module inside yet
P2 tilt angles are not user adjustable.
The rest is up to someone else :) .
Flying in ATTI or manual mode will give you more speed.
Not good to mess with the gain either.
You can have a play with the Pitch Roll and Yaw controls in the dji Companion app,
I have it on my mac and it works quite well.
Be very careful that you don't over do it and cause your drone to overspeed or tip.
Regards
The gain controls on the Phantom P2 will not affect speed or cause it to tip. This can only occur in manual mode in which case the gains are not utilized.
The reason I say that is their is very little gain control that we have the ability to change. Majority of those controls are for the automatic controls. Unless you have changed the Phantom by adding hardware or changing the center of gravity the default gains are the best settings for the most part.
akos9703
