Compass stuck please restart help
I am getting compass stuck errors lately too. Restart does usually fix the problem.
I would agree with Tyson that a calibration and IMU calibration should be your next steps, Niall.
I got the compass stuck error I restarted many times but no help, any ideas?
Also, check the compass sensor values in the GO app. Are there numbers showing or do they show zero?
If they show zero, the compass is probably bad or disconnected.
Reactions: JoBe
View attachment 73963 if you can't get it unstuck by flicking it on top and side then you will have to replace the actual IMU.
let me know if you'll need one, i have quite a few. fairly easy to replace.
circled item on the picture shows what you'll need. it has 4 plastic notches holding it down and one connector.
Saw a video about removing the IMU and tapping it with a screwdriver to free the stuck pendulum, not something i would want to do but worth searching on youtube for
