Changing braking to 70%?
It seems no matter how gentle I am with the sticks my P3A brakes real hard at speed.
Some have suggested a 70% setting.
And that this change will reduce potential shell cracking.
Has anyone found this setting helpful?
How do you change breaking speed?
Just don't forget, that when you change the braking speed, it increases the distance required for a full stop. It is a good thing to do though.
Reactions: Digdat0 and SHRED
You can adjust the brake in the app. Main Controller Settings, Advanced Settings, Sensitivity.
Move the slider down from 100 to where you are comfortable.
Notes - you need to be connected to your AC when making this adjustment. Also, if that setting is lowered your P3 will coast to a stop rather than stopping quickly. Be careful to not glide into an obstacle.
I had mine set for 70% for the majority of my total 50 flights. I just changed it to 90% and on the first flight with the new setting i found a stress crack on the motor mount . It could be a coincidence ,but I'll be setting it back down to 70% once I repair the crack.
Reactions: SHRED
