Can't find the answer minor setting
Lafitte, Louisiana
trying to find the this info but no luck im sure someone here can help . djo go for android,, Normally when i fly the map screen follows my drone and shows which way its pointing. I dont know what i did but the last couple flights the drone icon just flys out of the view on the map view screen i normally leave it small at the bottom and leave my camera view big. anyone out there know what i need to do to make it follow the icon again?? thanks in advance im sure its a simple solution but i havent had any luck .
If you are flying in a locale that does not have Wi-Fi or Cellular service, you need to cache you maps before hand. Just guessing on that answer, but sounds like what may be happening. To verify that theory, next time it occurs, switch the map over to large scale then zoom out. If you only see the small original area after zooming out then that is the issue I would think.
Jerry P
