Can't connect to PHANTOM 2 VISION Assistant
Xto
Hi guys,
I have downloanded the PHANTOM 2 VISION Assistant software, and followed the notes. But my phantom does not connect!
Can someone give me a guide on how to get this thing working?
xto
Hi thanks for your reply. How do you install the drivers? I downloaded DJI drive 2.02.
Should be able to just double-click the file DJI_Driver_Installer_2.02.exe and it will install. Should be in your downloads folder if you already downloaded it.
I was not able to install the drivers until the TX was actually connected via the usb cable. Once I did that, boom. Everything worked. Yes I opened the TX to gain access to the usb port.
Thanks guys, all sorted!
On upgrading I got the not intelligent battery pop up!!
What's going on! When you spend this much you expect things to work!
jorge sanchez
