can p4p camera be tilted 90 degrees?
can the camera of the phantom 4 Pro be tilted / rotated by 90 degree like with the mavic?
I would like to take shots with more sky on it and use it for panos as well.
Turning to take portrait mode shots is a Mavic exclusive trick but you can tilt the P4 pro camera up 30 degrees to catch plenty of sky.
Then take a second row to get more foreground detail and depth in your panos.
Reactions: KevMo Photog
yes, i meant portrait mode. but with the tip of doing it in two rows, it will be fine.
another questions, how to tilt up to 30 degree, my gimbal stops a zero degree and not 30?????
skysmurf
There is a setting in the gimbal option to enable gimbal tilt above 0 degress. Enable this and you should be able to tilt the gimbal upwards.
