camera tilts downward
Modesto, CA
P4. only when using Litchi in FPV mode, the camera is stuck in the down view. It will dial upward but goes back to straight downward view when released. This happens only when head tracking is on and is irregardless of android phone position.
what am I doing wrong?
thanks
Wow, that's odd. Have you checked your setup carefully, on your waypoints? Sounds like the drone thinks the camera should be pointed that way. I think that is called the "gimbal pitch" or something like that. I have not messed with mine much. I usually fly Waypoints missions and have the camera to "focus POI" or something like that. Might worth checking, just in case. It would be a cheap fix if that was the problem.
Thanks,
Jim
WA5TEF
Reactions: ptuner1
apktuti
