Camera Mods
Studiowise:
Can you post more pictures of your rig with the GO PRO attached? I'd like to try to do something like that as well. Do you have a link for the gimble you purchased off of ebay?
thanks
Jeff
Bad news...
"Thank you for contacting Sony Support.
I understand that you wish to know if a Wi-Fi repeater can be used to the camera to increase Wi-Fi distance. There are several environmental factors that can reduce the maximum range between a Sony Wi-Fi compatible camera and a smartphone using PlayMemories Mobile. Given ideal environmental conditions, the recommended maximum distance a camera can be connected to a smartphone is less than 5 meters or 16 feet. It is not possible to increase this distance and also not possible to use any Wi-Fi repeater.
If you would like to be the first to know about our latest products and receive exclusive offers, please sign up for our newsletter:
https://sonytextme.com
The Sony Email Response Team
C5GA
Bruce"
jfmm said:
Bad news...
C5GA
Bruce"
Does this guy knows what he's talking about?
Found this interesting info on connecting an QX100 to a drone: http://diydrones.com/profiles/blogs/exp ... ifi-camera
...and Sony is adding new features to its API, hopefully this will open up some possibilities to extend the wifi range. See https://developer.sony.com/2014/02/24/n ... d-cameras/
Does anyone know how to power the camera when not attached to the quadcopter? For some reason my camera is not receiving power (no LED's whatsoever) and I wanted to confirm its not the camera and only the cable.
vin100 said:
jfmm said:
Bad news...
C5GA
Bruce"
I already took a look on the API from Sony. To use it we need a device running android + FPV system + control link to the transmitter and a lot of burned brain cells.
It's a lot of weight for my fat phantom...
I did some tests this weekend with a tarot T-2D and QX10.
The limit distance is about 50mt (much more than 5 mt from sony team) but few for my needs...
But the big issue is the jelly effect. I think this câmera isn't apropriate for UAV's...
I take great photos in the air even with 10x zoom, but the vídeo is horrible!
I have tested the Phantom with the QX10 and shutter trigger... total extra weight with prop guards included is about 250 grams..
I am finding the P2 is drifting around all over the place , I have tried compass calibration without any improvement.. Anybody have any issues with the P2 drifting around (in GPS mode) with extra weight... PS , I am using CF blades... The blades worked fine without the extra mods...
jack klausner
