- Joined
- May 24, 2015
- Messages
- 3
- Reaction score
- 0
- Age
- 38
Please help I have the Phantom 2 Vision+ and the LED light on the gimbal is solid green. I cannot connect to it's wifi. The only things I have tried is power cycling everything and resetting the binding on the wifi extender. However that didn't fix my problem. Everything else works, I can even record video and take pictures using the manual button. I can the gimbal and full control of the aircraft. The problem is the video stream is not working. What options do I have? I got this in December 2014 and it is Version 3.
More Info:
This Phantom has very light use. I never crashed it. However it did have 2 hard landings where the battery popped out. The issue started happening a little while ago.
At first I could connect to the wifi but the camera app said no connection. Eventually I got it to work after power recycling everything 2-3 times.
Then it got worse taking 5-6 times and sometimes I couldn't connect to the wifi.
Now I can't connect to the wifi at all (doesn't show up).
The only time I can get it to show up is if I try to reset the binding. When I reset the wifi extender I can connect to that and put in the MAC address of the Phantom. Once that is done and everything is power cycled nothing shows up.
More Info:
