I thought you flew with earlier firmware and app versions. Did you change your mind, or have I made a mistake in my thinking?
I did, but decided today to bite the bullet and do an update :-(
Not true. I m able to select any format and any rate.Found a possible bug in software.
Video is stuck at 60fps at 1080p
I tried to reduce the frame rate and it flicked to lower frame rate but as soon as i lifted finger it went back to 60fps.
any one else ?
OH MY......
Is the recent firmware that much better now, or did you just want to go through the worrying again each time you fly?
I want more stress
I figured as much. Kind of thought it might be the adrenaline rush you were after.
I heard it's possible the top speed might be reduced in these new versions to match the P4's P-mode speed. Do you know anything about that?
I'm facing another issue. Can't set white balance to 5000K. It slides back to 6000.
