Bug in iOS 2.7.2 software ?
Found a possible bug in software.
Video is stuck at 60fps at 1080p
I tried to reduce the frame rate and it flicked to lower frame rate but as soon as i lifted finger it went back to 60fps.
any one else ?
I thought you flew with earlier firmware and app versions. Did you change your mind, or have I made a mistake in my thinking?
I did, but decided today to bite the bullet and do an update :-(
OH MY...... :confused:
Is the recent firmware that much better now, or did you just want to go through the worrying again each time you fly?
any one else ?
Not true. I m able to select any format and any rate.
I'm facing another issue. Can't set white balance to 5000K. It slides back to 6000.
I will give it a go in 10 mins, just transferring some video to my computer.
I want more stress :eek::eek::eek::eek:
I figured as much. Kind of thought it might be the adrenaline rush you were after.
I heard it's possible the top speed might be reduced in these new versions to match the P4's P-mode speed. Do you know anything about that?
I know, need to feel my heart pounding each time I do the update.
Not heard that about speed.
I will test out.
No, I can change it up and down and it stays there.
Also my frame rate is now working again.
Odd maybe its a funny connection thing.
