So I had a 19 panel 5.4kw solar array installed today and fired up the drone to help the company get some shots of the installation. Just to get the idea across I've got 81 flights and 7.5hrs in the air, and the only crash was when the dog attacked my P3S so unless my logs show otherwise the following event was something I believed to be just about impossible.
I noticed the bird wasn't holding position like it normally would, which my father was putting down to wind. I flew 2 days ago in MUCH worse wind that the little breezy bursts we were getting today. I should have brought her down and recalibrated immediately but I kept it up seeing if it's "station keeping" would improve. As I brought it around the front of the house to bring it down it drifted towards the front of the house.. I was completely aware the the bird was facing me, and pushed left on my right stick to correct it away from the house but it didn't seem to work, and she kept drifting until SMACK. The blades hit the siding and down she went. Thankfully i'm only out a set of props and after a recalibration all seems ok. The first flight up after replacing the props it was listing to the left, but recal. fixed that.
I'm trying to get the txt flight logs for that flight but I only see the logs from 2 days ago in my android phone. Can I do anything to analyze the .dat files on the bird? Where else can I get the txt files from??? I want to verify that I didn't accidentally push it into the house. I'm fairly certain I didn't but without the txt logs I can't be positive.
