Broken anttena
Hello,
I have DJI P3S and i have droprd the controller and antenna broke off...so drone is almost unusable i lost conection aftet 50 meters...what can i do ? warranty wont cover this damage...can i do some repair by my self...?
Sorry for bad english ;-)
@Danitur
That short of range, open up the controller check out the wire inside.
Rod
Give me 45 bucks and I will ship you a used but mint condition argtek kit I used on my ps3. I upgraded to p3p and sold it but took off the mod. I will also included a tablet mount for a p3s remote
So this i mount on my controller and i don't need antenna anymore...i would love this...but i am from Slovenia/europe...do you send in europe ?
If you take a closer look...on the first image in my post you can see that antenna cable is damaged alittle...
Danitur - If the range is now very limited I think the antenna wire may have been either broken or pinched as in the first photo or ripped-off the board inside the controller. Just breaking the external plastic part wouldn't affect range that much.
Argtek mod is the way to go, then you can swap antennas easily till you find what works for you,,and probably the cheapest way to get back in the air,
So i decided for argtek mod...is it easy to install it ? and does anyone know if i can get it in europe ?
There have been a few people that have upgraded from the argtek here that are trying to sell theirs,,one I saw was in your corner of the world,,I'll see if I can find that post,,
Reactions: Danitur
I bought this mod kit to correct the distance and signal problem with my broken antenna.
ARGtek DJI Phantom 3 Standard WiFi Signal Range Extender Antenna Kit 10dBi Omni | eBay
I connected everything as it should be, but now connection is even worse...i get only about 50-60meters of distance before i lose signal but if there is obstacle as tree i dont have a signal at all...what should i do ?
Is there problem with drone not the conttroler...how to know whithout sending drone to service?
TimCJWolfe
