Blade balancer
I’ve been doing research and came up with no luck is there a machine or someway to balance the phantom 4 props with those legs on them
Thanks in advance
Blue skies
Here are a few prop balancers you can use with P4 props:
I used a simple pencil point in a vice then bought a commercial balancer for about $35.00. The pencil point works just as well. I also found all DJI props to be in balance while two sets old carbon fiber props were not.
Just suspend the pencil in something, either vertical or horizontal and add the prop to the sharpened point. The heavy side will rotate to the bottom. Simply sand off some material near the tip to bring in balance. Or you can add tape to the lighter side.
Don’t fly without balancing for sure.
Good luck
Jim
WA5TEF
robvalduga
