Better Grip for iPad on Transmitter.
Hummingbird.UAV
Premium Pilot
Alberta
Website
www.youtube.com
I like to fly with a big screen but the mount on the transmitter was always wobbly no matter how tight the locking screw was. Here is my solution.
Looks good. Did you make it with a brake, or purchase it that way? If so where.
Does it interfere with the control sticks?
Nice idea. I no longer own a brake so I was hoping it was pre-made. If you don't mind giving me the dimensions I would appreciate it. Machine shop nearby, worth a few bucks. Assuming stainless. 1/16?
Here is a PDF with dimensions. It is important that the bends are exactly parallel. Also a piece of foam rubber is required on the lower lip.
Hopefully you can work with metric dims. If not give me a shout and I can convert the units in my CADD program.
Nice little bit of ingenuity. Neat little simple fix. I use an old iPad Air and I don’t seem to have that problem. It might be the angle that I look at the screen.
Will this work on the P3S Controller as well? Cool idea. Thanks!
