- Joined
- Feb 15, 2017
- Messages
- 30
- Reaction score
- 14
- Age
- 38
I'm very happy with the DBS and now I'll be getting close to the 3 mile club once I install my Sunhans signal boosters.Hmmmmmmm maybe you have a defective m25. Anyway at least you get good signal with dbs. I have argtek right now. Stock i went 2000ft. With argtek my furthest was 5200ft. I got 3 alphas on the way hopefully i can squeeze 8000ft out of them if not i will cry at the fact i should have got dbs in the first place lol
Hhhhm, that is almost three times higher than my tests. Have you any records of tests you did at lower altitudes? Very curious to see how my setup stacks up. I would try to max out my alt but not at the current location with too many curious onlookers.View attachment 76759 For sure the higher you fly the stronger the siggy remains.
I'm registered with the FAA and know the laws but this area is pretty desolate with no airports anywhere near so I climbed a little higher than normal.
Oh I believe you but seeing the two results makes me feel a bit more confident about my recent tests. Your ratios of distance over height are approximately 17-21 (i.e. 17 X 625=10625, 21 X 443=9300) My ratios (5000/247=20.) are almost identical and believe I may very well reach similar distances if I double/triple my alt.After spending hours and hours of reading forums, failbook, and watching YouTube vids I'm convinced it's location, location, location.
Wow [emoji15] I just got 2,709 feet with the stock antenna!!! I can't believe you guys aren't getting over 3,00 with Alfalfa and Argtek
Ok I'm off to test the Alfas one more time. I'll report back in a few hours.
Don't forget to mention your sweet wifi antenna mod kit Matt!
