Best is subjective but I have ended up with h265/30fps/dcinelike/ sharpness -1 the rest 0. I prefer f / 5.6 unless light prohibits thisI just got the P4P, can you guys share your camera settings for the best video quality in 4k?
Which color profile and which sharpness/sat/contrast settings?
Thank you!!!
Better detail overall. Both are 100mbit at 4K/30I've read up on this, and apparently the way dji encodes is that h265 does not give you better quality but only smaller file size. Have you found that to be true?
Just curious why you choose 265
Regarding resolution, it's OK to record in 3840X2160 X 60fps. 30fps is OK too, but stay away from 4096X2160 X 60fps as this doesn't work, it will produce glitches in the video.I just got the P4P, can you guys share your camera settings for the best video quality in 4k?
Thank you!!!
Cloudy is a whitebalance setting and only affects the balance between colors (red/blue temperature and purple/green tint). Cloudy is slightly warmer than the daylight setting. Auto is normally sufficient.Set your P4P for "cloudy" skies. This sets the iris in the best position to adjust between when the sun is peaking and when it goes behind a cloud.
A non-gradient nd filter only affects the shutter speed by reducing the amount of total light reaching the sensor. It does not affect color or contrast. Ideal shutter speed for 30 fps is 1/60 seconds and a nd filter will help reaching or approaching this as an alternative (or in addition to) setting the f stop.I also use an ND8 filter to enhance the color beyond the bright spectrum of the sky.
Set your P4P for "cloudy" skies. This sets the iris in the best position to adjust between when the sun is peaking and when it goes behind a cloud. I also use an ND8 filter to enhance the color beyond the bright spectrum of the sky. With those two settings, I barely have to do any adjustments in post production.
I second this. I made these adjustments and my photos and videos came out 10 times better.
You may have trouble replaying H.265 on some machines. Some editing apps don't support it either. It requires more CPU and GPU performance to decompress H.265 files, but it does store video in less memory. I'm staying away from H.265 until I get a PC that has a hardware decoding solution in a GPU for H.265, which is relatively new.I've read up on this, and apparently the way dji encodes is that h265 does not give you better quality but only smaller file size. Have you found that to be true?
Also a pro photog for 31 years and setting Picture Style to cloudy does nothing but just up the color temp of the file a little bit. Has nothing to do with the Iris or aperture like he was trying to say. LOL My settings are 3840 x 2160 @ 30fps. Love 24fps but you get a little stuttery as far as the footage look goes when ground or objects are moving fast in the frame. I set custom White Balance to 5000 and never touch it ever. I custom set White Balance for final project later in Raw conversion of stills or Premeir Pro with video. I always shoot totally Manual and am looking for an aperture close to F4.0 to F5.6. Best sharpness in that area! Use ND 8 or 16 all the time when in daylight and none at night. Also I use D-Cinelike and h265. Convert all my footage in premier to proxy files so premier can handle perfectly.I don't get what that is saying, I'm a photographer by trade, setting the whitebalance does not have an effect on the aperture (iris??)?? What is this about??
There have been numerous discussions and analysis on this here before, and it is probably not random that many use h265/dcinelike.Ok you seem to make most sense here on this thread. Then a question to you. Why Cinelike and 265. Can you share your thoughts on Cine vs log, and 265 vs 264?
Um, this doesn't really help as you give no reasoning why it works. Your statement could be applied to literally any piece of equipment. Setting your juicer to the most optimal juicing settings for the fruit you would like to juice is crucial.Photographers take still shots. When you are flying a drone, the landscape is constantly moving, thus, setting your Phantom for the most optimal settings for the conditions you are filming in is crucial.
O.k. Then clearly your supreme intelligence is way above my tiny little brain.. You bragged about being a 30 year veteran and then smugly ask a question in which, if you really didn't know anything about apature, iris and such, have no business asking... unless you were just using the question to cloak your arrogance about your experience.Um, this doesn't really help as you give no reasoning why it works. Your statement could be applied to literally any piece of equipment. Setting your juicer to the most optimal juicing settings for the fruit you would like to juice is crucial.
A video is essentially a sequence of still shots so the same settings for a good still image will give the best results for each frame of the video image. I guess for a true cinematic look you actually want to lower the sharpness of the video image using the standard 1/60 exposure, but white balance settings won't help here.
Ummm no dude! Best still settings will not provide the best video settings most of the time! Frame rate is key for the cinematic look you speak of! None of what you said makes sense at all. Lowering sharpness to the standard 1/60 exposure?????? LOL What does that even mean??? You want faster shutter speeds especially if it is windy for your stills. And then you want the slower shutter speed like double your frame rate to get the best cinematic looking video. So you are def changing back and forth if you are trying to do both stills and video the best!Um, this doesn't really help as you give no reasoning why it works. Your statement could be applied to literally any piece of equipment. Setting your juicer to the most optimal juicing settings for the fruit you would like to juice is crucial.
