Hello, anyone knows which is the best altitude for long range without interference problems?If you go higher is better?
Why does it take power to descend? If hovering, I'm going to slow the motors to descend, thus should use less power during descent. Same should hold true if in forward flight if descending at the same time. . Should use less power than maintaining altitude or climbing. Am I missing something here?2) It takes power to both ascend and descend. If you are going for distance, you need power.
That was not worded especially well - a quad takes power to stay up, period (duh). You can actually use up a lot of battery by descending rapidly then slowing down quickly - or changing direction quickly. If you are going for distance, you would want to avoid all unnecessary movements and concentrating on going in the direction you wanted to .Why does it take power to descend? If hovering, I'm going to slow the motors to descend, thus should use less power during descent. Same should hold true if in forward flight if descending at the same time. . Should use less power than maintaining altitude or climbing. Am I missing something here?
