SVI said:I recently purchased the Phantom and I just put brand new lithium batteries in my transmitter and it is non-stop beeping and the red light is blinking.There has only been one time that I turned it on that it didn't do this. Any ideas?
iphilms said:Actually my transmitter constantly beeps even with the left throttle stick down. Brand new out of the box. But it seems to work ok when flying my phantom. It just doesn't stop beeping. Any ideas whats going on ?
auck said:iphilms said:Actually my transmitter constantly beeps even with the left throttle stick down. Brand new out of the box. But it seems to work ok when flying my phantom. It just doesn't stop beeping. Any ideas whats going on ?
usually the beeping from the transmitter is caused by two things:
1) left control stick is not all the way at the bottom position
2) low battery -- battery needs to be changed
if you have the control stick all the way down, you may need to double check the calibration of the transmitter. but if you put used batteries into the transmitter, then you need to put brand new ones in there.
auck said:blinking red light means the TX is trying to link to the Phantom.
Darrell1 said:auck said:blinking red light means the TX is trying to link to the Phantom.
Are you sure? How does the transmitter know it has linked? I did not think the Phantom did any transmitting at all, just receiving. So, no back & forth communication.
FlyingFanta said:Darrell1 said:auck said:blinking red light means the TX is trying to link to the Phantom.
Old thread but it'd be nice to get an answer to this. My transmitter recently did this a couple of times. Changing batteries helped but the beeping came back quicker than I expected with these freshly charged eneloop (sp?) batteries.
OI Photography said:The Phantom Tx will also beep if left on for a while with no input (as a reminder)
FlyingFanta said:OI Photography said:The Phantom Tx will also beep if left on for a while with no input (as a reminder)
Oh thank you. I had the controller on while going through the naza assistant and I was puzzled at why the hell the battery sucked so much. Then I saw how high the voltage was and thought maybe the transmitter or received was hosed.
Thanks, it was the throttle stick not being in the down position. Much appreciated.
