- Joined
- Dec 28, 2018
- Messages
- 62
- Reaction score
- 55
- Age
- 70
I have a non DJI battery for a P3S. Noticed today that it is a little puffy. Air data says it's ok. No deviation. All looks fine. Should I keep using it?
You didn't finish the sentence, ish.If it catches fire and falls in the sea....Guess it's time for Mavic. Great excuse fir the wife.?
If you were to hold the presupposition many do that anything that involves spending money for your exclusive enjoyment might require consent from your partner you wouldn’t have missed this. To most that wouldn’t seems to be an incomplete sentence.You didn't finish the sentence, ish.
"...great excuse fir the wife ta kill ya in yer sleep!"
What mine keeps saying, anyway...
Brad
@itechnology "An inertial measurement unit (IMU) is an electronic device that measures and reports a body's specific force, angular rate, and sometimes the orientation of the body, using a combination of accelerometers, gyroscopes, and sometimes magnetometers...."
Making that thang ready
Brad
I was, however, assuming there were, potentially, those viewing said post with which this concept had not been fully implanted, be it by lack of marital maturity, or perhaps a stroke of pure luck. Therefore, I felt it necessary to finish said sentence so that I may help to prolong a fellow drone pilot's life until such time that said wife has reached the point of no return, and is forced to impale said drone pilot with a long, sharp instrument during his slumber... ? ?If you were to hold the presupposition many do that anything that involves spending money for your exclusive enjoyment might require consent from your partner you wouldn’t have missed this. To most that wouldn’t seems to be an incomplete sentence.
Ok. Guess my first question is, is this possible on P3S? Where do you look for that? Is it in A/C settings from setup screen? I'll throw mine in the freezer!There is a simple way to reduce IMU heating time ...
I calibrated my IMU in winter ... outside in about about -5 .. -8C weather ...
I made sure AC was cold by leaving it our there ... then with battery from my pocket - so it would work immediately ... I powered up and into IMU as fast as I could ...
Why does this work ? It appears that IMU calibration uses the ambient temperature as its reference .. so the lower you can get it - the better.
It will speed up your cold weather starts and makes no problem in warmer weather.
Under advanced settings,,,has compass and imu here,,,I put mine in fridge ,crazy but does workOk. Guess my first question is, is this possible on P3S? Where do you look for that? Is it in A/C settings from setup screen? I'll throw mine in the freezer!
Brad
Where would one "get rid of" a battery? Just in regular garbage?I just through out a battery that was a little puffy. It still worked and fit in the drone.But why take the change of catching your drone fire,
Get rid of it.
