Battery fit
Hi guys,
Just wondering if any.of ye had any issues with batteries not fitting correctly.
Its like the body of the battery isn't moulded correctly for the body of the drone, it will click in but is loose on the underside.
Thanks for any help
This is a known issue with the current battery model. If it does not fully click into place when you insert it firmly, then you should return it.
Reactions: bumblebee14
Hi thanks for the reply, ya its such an awkward design, way too many curves to match up with the body, the slightest bit out of shape and its not going to work
