Battery firmware change
I'm interested to know as well,.... Anyone did that?
How do you know what firmware your smart batteries have. There's nothing in the assistant software to indicate what firmware your batteries are using.
In the 3.8 assistant there is a tab labeled upgrade and it lists all the current versions you are running, including batteries.
You are correct about current versions your system is using but it doesn't indicate which firmware the battery itself is using. Beside that v2,6 battery update was pulled by DJI and no longer works.
loracle
