- Joined
- Feb 21, 2017
- Messages
- 779
- Reaction score
- 680
Most of the this video was shot in ATTI mode. It was very hard to control the drone.
You are very brave!! Did you have visual contact with the drone?
In atti mode, the gps/glonass is still enabled, but doesn’t position the drone. Just shows the location of drone. Unless in p-atti or f-atti. That means that drone can’t find a gps signal.
A stunning gorge!
Obviously, in this video you've got approximately 30 seconds of badly over-exposed footage from 2 minutes onwards
The drone was in regular P mode at launch. But it went into ATTI mode as soon as I entered in this cave-like place. I had zero satellite and no GPS signal during the entire flight. I turned VPS and OA off even before the flight.
Here is my tip for practicing in atti mode. First, download the map of your area by hooking your phone/tablet to wifi or turning on data or connecting to a hotspot. Then, Open the dji go interface and turn on cache map automatically. Do not turn on calibrate map coordinates. Wait until you see your location. Then, get off the wifi network and connect to drone. It is okay to leave on cellular data. Do not leave on your bluetooth hotspot. Just causes interference. Finally, find a nice and wide area and make sure your drone is in p-gps. Then, takeoff and get to a good height. Finally, put the switch into atti mode. If your feeling scared, Simply put it back into p-gps mode. Here are some important pointers with atti mode. Do not turn off rc or fly on low rc battery. You should also fly more close. I don not suggest tking off in atti mode first or flying drone in p-atti, unless you are an expert pilot. p-atti means that there is no gps available, so you shouldn't fly far away, even though you know how to get back. Better feel safe than sorry. Remember atti mode means altitude hold. It will only hold its altitude with the internal barometer. It will drift.Most of the this video was shot in ATTI mode. It was very hard to control the drone.
The 30 seconds or so I was referring to seem extremely overexposed, not something I've seen in your footage before. Perhaps the snow caused it? Or your settings were unusually off the mark for some reason? We always use manual settings, but auto is probably a safe bet when you're not sure - especially after trying every time of the day.
I fully appreciate that some situations, such as when filming dramatic gorges, are always going to be impossible to perfectly expose overall and this will mean compromise one way or another according to what you think is the top priority.
Almost all of our filming takes place during golden hour - usually immediately after sunrise, rather than near to sunset, simply because the winds are often lightest earlier in the day on the reserve. Sometimes, one or more of our mountains get in the way until the sun is high enough in the sky, so there has to be realistic adjustments if a location/shot is required. And working this out in advance, of course, is essential. Shadows are more acceptable during golden hour than in harsher light.
Thanks for the suggestions. I prefer to fly in regular P mode whenever possible but in this cave-like place ATTI mode was the only option to fly. There was no GPS signal. I didn’t select ATTI mode on RC, the drone was in ATTI mode even while launching.
If you get a compass error, first try to calibrate the compass and move to a different area. If that doesn’t work, don’t fly or just use atti mode. If this keeps happening, you should probably get a new imu, compass, and gps or just send the drone to dji to get fixed.
