Argtek question
Yes, in Blue Ridge Valley of Virginia.
Here is another of my favorites. I called my friend up and told him to go outside and look in the sky for my phantom. I flew two miles to his back yard.
Reactions: Webby
Thanks for the reply. My argtek has got panel antennas just like your but I'm a bit disappointed with them to be honest. Think I will go with the Maxx uav type they have good reviews
It's not a kit, just some antennas. You will need the Alfas and the clean install cables from the link above.
I recently installed the argtek ext1 kit and have had minimal results. Maybe a 10% over stock. I am currently in southern arizona and every direction is los. I bought my drone used, is there a common problem with the p3s loosing power on the RC side ? Even with the factory antennas I was only getting half the range advertised. Its like i am trapped in a 400 foot bubble in all directions that i cant break out of without loosing Signal. Thanks
I never had any luck with that setup either. I ended up going with a Itelite . In this case you get what you pay for.
drone-antennas
You hot a link for the Alfa panel kit mate ?
In post #5, he posted a link..... It's not a "kit", more of a DIY. See the post below this one for the cables you'll need. You buy 2 cables and 2 Alfa panel antennas and BAMMMM, you have a cheap range mod that works really really well.
Sorry I got a little confused and was thinking he was talking about a standard not an adv. I'm not sure where around Tucson would give you problems. unless your by one of the air bases or Bombing range.
Protocloudtechnologies
