Anti drop pins
Just bought phantom 3 ,out of the box it had 2 anti drop pins installed is that correct or do i need to install the other 2 it cam with???
Two installed is normal and sufficient. Other two are simply spares.
Does it affect camera with 4 on the gimble???????
Never tried it so, I'd be guessing to what extent...but yes, it would further restrict the range of motion of the shock absorbers. I suspect you'd only notice a difference (with possible video vibration) in extreme situations.
The dampers hold the gimbal on and cushion vibration at the same time.
The anti-drop pins are just insurance and don't do the holding.
Reactions: byron merritt
I use two of the pins and add two small zip ties very loose on the other holes. Has not affected my vibration.
