Hey all, so now my phantom pulls to the right in GPS mode. Has anyone else ever experienced this before? I've tried recalibrating (basic and advanced), and the compass dance to no avail. I am not sure what is going on with my phantom anymore.
Mine will go straight all day long. It just won't hold still.
Did you change anything near the top of the hood, the GPS area?
I did and wish I had not.
Try your original props just to eliminate the props as being the issue. One of mine was broken at the tip and made my quad drift to the left. After I replaced it, all was good. Just a suggestion, but it worked for me.
I would suggest you open up the quad and check the connections. I usually start looking at the last thing I did before I had problems.
I changed my landing gear and the compass is still on right rear leg but it is back a little further and angled slightly different. Now phantom wanders all over the place in gps mode only. I thought once I did the compass dance it would be fine but I guess the compass has to be angled the same as from factory. Anyone have any knowledge on this subjuect?
dji phantom fc40
ardrone2 mod 4 telemetry+fpv
tplinkwr703+sunhans 2.5w and alpha 7dbi panel antenna for wifi boost
based in new jersey US
dji phantom fc40
I checked the mod data and all was in spec, I have a good non magnetic screwdriver set for this purpose. If the compass is not in parrellel with the naza controller it will not function properly. I have verified this with another member who did the same thing with his landing gear. Thanks for the heads up tho
Hey, just curious about what you changed near the top gps area. I was wondering if you were talking about the foil gps insulation mod/fix or something else. I was thinking about doing that to mine but will not if u had problems with itMine will go straight all day long. It just won't hold still.
dji phantom fc40
