all-new out-of-the-box, all updates, won't tilt
Gads first post and it has to be a problem!
Disclaimer: HAVE read thru a bunch of 'no tilt' threads. Nothing seems similar
specs:
brand new P2/3D kit.
Freshly mounted 3D - no flight time. Interference board installed
_______
Software updated today:
Main Contr: 3.04
P330CB (wot ever that is!): 1.0.1.27
Zemuse: 1.0.0.6
__________
First boot up (before above upgrade):
-gimbal aims DOWN, no TILT control on TX (ie inoperative TILT)
-gimbal does maintain motion in other axis
Upgrade as above:
-gimbal rights itself (yay!)
-BUT: running the X-1 calibration: FAIL - no control with tilt control, nor response on the x-1 to the TILT lever.
-AND: if I use the LEFT Stick and push LEFT or RIGHT - gimbal PANs L or R! (follows stick motion) (does this in either Standby/preflight mode OR spun up for flight)
Thoughts?
my thanks
Stu in Alaska
Go to the DJI Phantom RC assistant software, click 'Advanced', go to 'Gimbal' and calibrate the H3-3D there. My tilt is set to 2, horizontal & vertical both at 0.
Hope this helps.
IO-
I would check that out if someone can point out where the 2 leads are?
Stu
Alaska
Just want to update here...
Contacted my Dealer (Davesmotors.com) and we did some back-and-forth email solutions:
-make sure the tilt lever is not stripped on its post (wasn't)
-remove is and rotate the Tilt shaft fully L&R to the "stops", while running a X1 Cal in the RC Assist.
Discovered: there IS no "stops" - shaft will spin either way infinitely. So my Q was: is the potentiometer bolloxed?
Dealer seems to think so and has requested a new TX from DJI.
Did note a thread here that numerous folks had bad X1 lever/potentiometers out of the box too.
Will update as it unfolds....
Stu
Alaska
Try calibrating first using the RC Assistant and move the switch a couple of times and then calibrate using the Phantom 2 Assistant doing the same switching a few times.
That happened to me after I updated all firmware, the gimbal tilted facing down permanently. Everytime I toggle the switch it'll twitch but then return to the facing down position.
Thread below is what helped me fix the issue:
viewtopic.php?f=8&t=6544&start=10
Hopefully this'll help you too.
My thanks for pointing out this thread.
My Dealer seems convinced the problem is with the remote control (so, a mechanical issue?) rather than software, and has contacted DJI on my behalf to replace this under warranty.
DJI has acknowledged the request (quick!) so I will see what this produces.
Meanwhile - I will give this a go!
Stu
Alaska
Seeclear007
