all-new out-of-the-box, all updates, won't tilt
Discussion in 'Zenmuse H3-3D/H4-3D GoPro Gimbal' started by 7aull, May 22, 2014.
  1. 7aull
    Gads first post and it has to be a problem!
    Disclaimer: HAVE read thru a bunch of 'no tilt' threads. Nothing seems similar
    specs:
    brand new P2/3D kit.
    Freshly mounted 3D - no flight time. Interference board installed
    _______
    Software updated today:
    Main Contr: 3.04
    P330CB (wot ever that is!): 1.0.1.27
    Zemuse: 1.0.0.6
    __________
    First boot up (before above upgrade):
    -gimbal aims DOWN, no TILT control on TX (ie inoperative TILT)
    -gimbal does maintain motion in other axis
    Upgrade as above:
    -gimbal rights itself (yay!)
    -BUT: running the X-1 calibration: FAIL - no control with tilt control, nor response on the x-1 to the TILT lever.
    -AND: if I use the LEFT Stick and push LEFT or RIGHT - gimbal PANs L or R! (follows stick motion) (does this in either Standby/preflight mode OR spun up for flight)
    Thoughts?
    my thanks
    Stu in Alaska
  2. zipkicker
    Go to the DJI Phantom RC assistant software, click 'Advanced', go to 'Gimbal' and calibrate the H3-3D there. My tilt is set to 2, horizontal & vertical both at 0.
    Hope this helps.
  3. britchris1
    Manchester, NH
    Do the standard stick calibration but before you hit finish toggle the x1 lever a couple of times. That did the trick for me.
  4. 7aull
    Thanks for the input guys-
    no go. no change....
    :cry:
    Stu
    Alaska
  5. OI Photography
    Clarksville, TN
    Sounds like maybe the leads from your receiver board to your NAZA have gotten switched...the one in X1 should be in X2, and vice-versa.
  6. 7aull
    IO-
    I would check that out if someone can point out where the 2 leads are?
    Stu
    Alaska
  7. 7aull
    Just want to update here...
    Contacted my Dealer (Davesmotors.com) and we did some back-and-forth email solutions:
    -make sure the tilt lever is not stripped on its post (wasn't)
    -remove is and rotate the Tilt shaft fully L&R to the "stops", while running a X1 Cal in the RC Assist.
    Discovered: there IS no "stops" - shaft will spin either way infinitely. So my Q was: is the potentiometer bolloxed?
    Dealer seems to think so and has requested a new TX from DJI.
    Did note a thread here that numerous folks had bad X1 lever/potentiometers out of the box too.
    Will update as it unfolds....
    Stu
    Alaska
  8. SrAMagistrado
    Try calibrating first using the RC Assistant and move the switch a couple of times and then calibrate using the Phantom 2 Assistant doing the same switching a few times.
    That happened to me after I updated all firmware, the gimbal tilted facing down permanently. Everytime I toggle the switch it'll twitch but then return to the facing down position.
    Thread below is what helped me fix the issue:
    viewtopic.php?f=8&t=6544&start=10
    Hopefully this'll help you too.
  9. 7aull
    My thanks for pointing out this thread.
    My Dealer seems convinced the problem is with the remote control (so, a mechanical issue?) rather than software, and has contacted DJI on my behalf to replace this under warranty.
    DJI has acknowledged the request (quick!) so I will see what this produces.
    Meanwhile - I will give this a go!
    Stu
    Alaska
Similar Threads - box updates won't Forum Date
Standard Phantom 3 Standard, 5.8ghz pepperbox 23rd birdside? Phantom 3 Help Monday at 10:48 PM
Phantom 3 Advanced - drone only with original box - $215 Classifieds Monday at 5:31 PM
Simulator for Xbox or another gaming system Phantom 4 Discussion Aug 5, 2017
For Sale - P3 Batteries (Used) + P3 Pro 4K Camera (New in Box) Classifieds Aug 4, 2017
Neat little box for the P4 Pro Plus Phantom 4 Pro Discussion Jul 17, 2017
