Out of box gimbal failure & left stick lock in decent
Discussion in 'Phantom 2 Vision + Help' started by Grandpa's Quad, Aug 16, 2015.
  1. Grandpa's Quad
    Hello all,
    I'm beginning to feel the pain I have seen posted regarding DJI's quality control. I just received my fly-a-way replacement from DJI direct. They did upgrade me to a P2V+ 3.0 so no complaint. However, upon setting up the quad on my desk to test everything I found that two things. First the controller (new style with corner camera tilt) locks into the decent position. Not sure if new feature, but kind of scary, I'm thinking defect. Second upon power up the gimble points camera nice and straight. As soon as I make the slightest adjustment to the camera it rotates and locks into 90 degrees. The corner rotate dial will let me rotate the camera back a full 90 to straight but as soon as I let go of the dial it goes right back to straight down.
    I've searched for this and have found a few threads but no fixes. Again, thinking defective gimbal. Thoughts on both issues left stick and gimble.
  2. hunch
    update firmware on the controller via RC software on your PC, then calibrate the controller in RC software.
    switch to phantom and start P2 software and do calibration of the controller again and then hit Start button to calibrate the tilt wheel.
    finally check Upgraded controller instead of Basic in P2 software under Basic tab - RC
    calibrate compass,
    turn off and turn phantom on,
    wait for homelock,
    FLY!
    and yes, it is normal that the throttle stick sticks all the way down on V3 controllers.
    no worries, as long as barometer in NAZA is sensing movement you can pull it all the way
    down and motors won't stop.
Similar Threads - box gimbal failure Forum Date
Out the box won't calibrate compass. And gimbal exceeded limits Phantom 4 Discussion Dec 27, 2016
Gimbal wacko out of the box.... Standard/4k Discussion Dec 17, 2016
Gimbal issue it of the box Phantom 4 Help Sep 23, 2016
camera/gimbal for P3 Pro. new in box. Canada shipping only Classifieds May 27, 2016
Gimbal problem out of the box Phantom 4 Discussion May 7, 2016
