If the altitude limit is set by the barometric pressure at the time of setting home point, you could place the Phantom in a sealed container and pump out a bit of air to simulate a higher altitude, power up, set home point, open the box and then launch.
Most people (with a couple of annoying exceptions) want to remove the altitude limit because the ground is not flat. I have to contend with 125 foot trees. If there is any slope to the land - which happens with distressing frequency in the mountains - you may no be going very far before you hit altitude limit while remaining just over the treetops - safe from high winds and low flying Cessnas.
Are you being a smart a$$???Here's a thought...hike/climb to the top of the mountain and fly from there. Are there any issues with flying BELOW the take off elevation?
Who cares? The real discussion is either set the height limit at 400 feet or none at all. Setting it at 500m seem arbitrary and is already against the FAA recommendation, so why bother at allif not setting it at 400 feet? Explain that one to me.Now, clearly articulate to me what you plan on achieving with 500m height restrictions lifted? I'm curious...
Are there liability for library or the publisher or author for having a book titled "Anarchist Cookbook"? Google it if you are not familiar with this book.This is to be expected with every 'new wave' of Phantom releases or ownership.
It can be frustrating until you realize you don't have to participate.
One solution is to not allow ANY threads which entertain altering, hacking, etc. the Phantom's inherent safety systems or equipment.
Like many, I chat in other forums on different interests and depending on the subject ANY talk of "bypass this" or "disable that" and similar are a No-No and swiftly removed.
It may come to this as a liability issue for the site.
Totally agree.Who cares? The real discussion is either set the height limit at 400 feet or none at all. Setting it at 500m seem arbitrary and is already against the FAA recommendation, so why bother at allif not setting it at 400 feet? Explain that one to me.
Not at all. I just got a P3P and plan to fly it from the tops of some mountains. Are there any issues I should be aware of in regards to flying below my take off elevation?
Good. [emoji3]Not at all. I just got a P3P and plan to fly it from the tops of some mountains. Are there any issues I should be aware of in regards to flying below my take off elevation?
Having to climb on top of the mountain kinda defeats the whole purpose of having a drone. You might as well limit the range to 50m and then say, "Here is a thought. Walk closer to what you want to film".Here's a thought...hike/climb to the top of the mountain and fly from there. Are there any issues with flying BELOW the take off elevation?
Yes these british RAF fly low and fast weaving through the valleys, few times i called the numbers given to issue a NOTAM informing them i would be flying a hang glider and given the co ords, would tell the the time of arrival and a time i would land and go home if i could,nt get up and away from the area, i was nieve and assumed they would stay out between those times,I agree the limit is purely arbitrary. I live in amongst mountains and find the restrictions a pain. In the UK you aren't supposed to fly above 400'. I have often seen aircraft flying BELOW my house so I can't work out whom this height limit is protecting.
Ok, i took your "liability" as a legal one rather than a generic business one.It's purely a business decision not a First Ammendment one.
Zeran v. America Online, Inc. (1998) provides website owners immunity from prosecution for publishing thrid-party content but not from the financial 'fallout' of any bad 'press' or P.R as a result.
It all about the $$$s.
