1.8 degree camera tilt
Other than editing video and stills in post, is there a way to fix a 1.8 degree camera tilt on the Vision +? I tried opening the gimbel arm and checking to see it was aligned properly (looks like it is but a 1.8 degree tilt would be tough to see on such a small part). IMU calibration (advanced) does not fix it either.
Have had a couple hard landings but no major gimbel impact that I am aware of. Now I have a plexiglass shield as well.
Sure wish there was a gimbel adjustment tool.
MT
lsteigerwalt said:
Other than removing the back and adjusting manually there is nothing that is known to work. And once its adjusted it doesnt always stay unless you use an adhesive.
+1 Fix is below.
viewtopic.php?f=27&t=20514
If you haven't crashed and all of a sudden you have tilt, try to take up catch landing techniques.
Bump landings can cause the tilt. I cant prove it though. You have an axis-shaft that is held by tiny pressure. Just a bump will dislodge it. Keep doing this frequently and it will come loose and misaligned. It will then try to re-align in mid flight and dance and then tear the cable.
Don carlos
