Read the questions you will have to answer for the for the 107.29 waiver for part 107. These are all for safety reasons. Why is it that these will not have to apply for recreational use under the reauthorization act. It does not make sense to me.
Technically not correct. As of the signing of the FRMA 2018, a hobbiest is flying under 349, which for all intents and purposes is the same as 336.As a hobbyist you are flying under part 336 “Recreation Flyers & Modeler Community-Based-Organization” , and as such you are required to follow the guidelines of a model aircraft community-based organization. Read below bullet point 3, where you agree not to fly over moving vehicles.
https://www.modelaircraft.org/sites/default/files/100.pdf
So can hobbyist as of now fly in lets say class B air space and at night?
Sure why not they dont have a 107 license. They can even fly up to the 10,000 ft limit of class B air space. I wouldn't but what does a hobbyist have to lose other then some money their drone and freedom.
I think it's time to stop beating the dead horse. Responsible flyers fly that way, regardless of Hobby status or as you seem to think as a Part 107 Pilot " Premadonna" Status. Personally I look at both the in the same manner. I have no need, nor want for 107 status. I fly per the rules and guidelines set forth, and never in a "reckless" manner. Take that as you will, but you are simply adding gasoline to the fire by your comments. I usually do not comment on these issues, other than an original OP's question. Enough is enough. Being a Part 107 Pilot also requires common sense, as does a hobbyist flyer. If you have issues with that then I suggest you take those arguments elsewhere.Sure why not they dont have a 107 license. They can even fly up to the 10,000 ft limit of class B air space. I wouldn't but what does a hobbyist have to lose other then some money their drone and freedom.
No,, a hobbyist cannot fly within 5 miles of any airport. Plus a hobbyist cannot fly within Class B airspace if it extends beyond 5 miles down to below 400 feet. Yes there is a provision that a hobbyist can notify the tower, but I doubt you will get clearance in Class B airspace.
Just personal opinion, but I have always considered the use of Goggles to be in violation of this portion. Never used them, never will. The only way this should be allowed is to have a spotter in tandem with the Pilot. No exceptions for either hobbyist or 107.Fly within visual line-of-sight, meaning you as the drone operator use your own eyes and needed contacts or glasses (without binoculars), to ensure you can see your drone at all times.
