I posted this some time ago but it keeps coming up. Here it is again
It's not the room it's my voice. I have a really bad speaking voice. That is why I hesitated doing this video. I should have someone come in an narrateGreat Video but the voice is hard to hear because the room is bare.....Thank you Ted
+Hey Ted i cannot get the motor of the old yaw arm because of the small crappy screws dji used (2 stripped) looks like I might
to purchase a new yaw motor (the ribbon looked a bit sus anyway).
The yaw arm is aluminum so grind around the screws not the screws. You can then use my method to replace the windings and keep your casing. I have done this. You are only trying to save the casing with the magnets.View attachment 94333 View attachment 94334 View attachment 94335 What a pain got 1 screw out but the other 2 screws stripped so ted you say grind them out...hmmm that's going to fun.
Don't worry I will. However I am 73 so how much longer can I stay up to date with all the changes DJI might send down the pike? Or I might just die today. If that happens I am going to slow way down.I had no problem hearing or understanding you. Perfectly clear on my device. I thought it a great video & could be very helpful to someone needing this. Please don’t stop making videos as yours was very well made.i hope you continue making videos as I may need one someday. [emoji111]️[emoji256][emoji573]
Thanks. I added CC today . that should helpTed....Im older then You and i agree with what you said too 100% Thanks again for the video and your reply's to help that one guy...i used ear phones awhile ago and it was much better audio for me.
That is not good. You can put the new windings in that housing but I suspect it will not function correctly. I would give it a go and hope for the best. If it doesn't work, you can sell the camera on eBay, then buy a replacement. You will get about $100 for it. Your only other option is to send it to me and I can see if one of my yaw motor casings will center it. I have about 20 good casings. The odds are somewhat low.Ted I removed the motor housing this morning and saw this, what do think?View attachment 94467
you are welcome. Glad it was of help. By the way, the sensors are the same on the pitch and roll motors however you can swap them out directly without any issues. It is just the Yaw that has to be treated this wayThanks Ted for the info...your a life saver.... Here are the pictures of my yaw motor with bad sensors.
