Yaw Arm wiggles at shafts for Yaw motor
Mountain City, TN
I hope my description is accurate.
Where the top of the Yaw Arm connects, there's a set screw that tightens on a flat sided shaft, which I believe is the Yaw motor shaft.
Anyway, there is some play or wiggle at that point.
I noticed my gimbal shaking last week (a day or so prior to a crash) while hovering at eye level, which I thought seemed odd.
Now I'm replacing the gimbal ribbon cable, and notice what looks to me like an abnormal amount of play. Wondering if this looks abnormal to anyone else.
I have a gimbal thats apart at home, once I get there ill see if mine has any play with/without the cover on.
Think once the set screw is in, there should not be any wiggle :)
Does it wiggle like that once the cover is back on?
Yes, I actually noticed the wiggle before disassembly
Let's say the set screw is at 12 o'clock, the wobble is from 9 to 3.
I can agree that tightening the set screw may reduce the wobble, I would think that from the factory, the Yaw Arm would slide on the shaft with very little play....less that what my video shows.
The set screw wasn't even very tight. I didn't have the correct size allen wrench, and was able to loosen the set screw with an Allen wrench slightly larger than the set screw.
I may try to shim this a little.
You may want to get some threadlock and apply it to the screw as well to hold it in place.
rockymountaincaptures
