WOW $1259!!!
Let me guess....you have no intentions on upgrading to a P3 which might explain why you have been posting in the manner you have?
you got that right, battery capacity drives the boat, and this bloated boat wont go far
I bet the Inspire people are VERY pissed off
The P3 batt. has about 10 watts or 15% more capacity +/-
P2- 11.1v x 5.2Ah= 57.7W
P3- 14.8 x 4.48= 66.3W
No I'm sure they are happy with their $2000 landing gear.
P3
V3 is not P3.
I never said it was. The V3 is now showing out of stock and not available. Totally unrelated to the P3.
All I am say is in the last 30 minutes you can not buy a V3 now.
I looked at DJI Store's prices for different countries and seems like it's quite expensive for the Brits. 1159 quid which with today's currency rate is over $1700.
To me it would cost 1400€ which equals to little over $1500 but I realized it contains the 24% value added tax we pay here in Finland.
12.9%
that is not enough to carry the additional power burdens
Really,
Please share your power burden data.
Weight (including battery and propellers)
1280 g
Diagonal size (including propellers)
689 mm
Max Ascent Speed
5 m/s
Max Descent Speed
3 m/s
Hover Accuracy
  • Vertical: +/- 10cm
  • Horizontal: +/- 1m
Max Speed
16 m/s (ATTI mode, no wind)
Max Altitude Above Sea Level
6000 m
Operating Temperature
0°C to 40°C
GPS Mode
GPS/GLONASS
Camera
Sensor
Sony EXMOR 1/2.3” Effective pixels: 12.4 M (total pixels: 12.76 M)
Lens
FOV 94° 20 mm (35 mm format equivalent) f/2.8, focus at ∞
ISO Range
100-3200 (video) 100-1600 (photo)
Shutter Speed
8s -1/8000s
Image Max Size
4000 x 3000
Still Photography Modes
  • Single Shot
  • Burst Shooting: 3/5/7 shots
  • Auto Exposure Bracketing (AEB): 3/5
  • Bracketed Frames at 0.7EV Bias
  • Time-lapse
Video Recording Modes
Phantom 3 Professional
  • UHD: 4096x2160p 24/25, 3840x2160p 24/25/30
  • FHD: 1920x1080p 24/25/30/48/50/60
  • HD: 1280x720p 24/25/30/48/50/60
Phantom 3 Advanced
Supported SD Card Types
Micro SD
Max capacity: 64 GB. Class 10 or UHS-1 rating required
Max Bitrate of Video Storage
60 Mbps
Supported File Formats
  • FAT32/exFAT
  • Photo: JPEG, DNG
  • Video: MP4, MOV (MPEG-4 AVC/H.264)
0°C to 40°C
Gimbal
Controllable Range
Pitch -90° to +30°
Stabilization
3-axis (pitch, roll, yaw)
Vision Positioning
Max Velocity
Less than 8 m/s (when 2 m above ground)
Altitude Range
30 cm-300 cm
Operating Range
30 cm-300 cm
Operating Environment
Surface with clear pattern and adequate lighting (Lux > 15)
Remote Controller
Operating Frequency
2.400 GHz-2.483 GHz
Max Distance
2000m (outdoors and unobstructed)
Video Output Port
USB
0°C- 40°C
Battery
6000 mAh LiPo 2S
Mobile Device Holder
For tablet or phone
Receiver Sensitivity (1%PER)
101 dBm ±2 dBm
Transmitter Power (EIRP)
  • FCC: 20 dBm
  • CE: 16 dBm
Working Voltage
1.2 A @7.4 V
Battery Charger
Voltage
17.4 V
Rated Power
  • 100 W
Phantom 3 Advanced
  • 57 W
Intelligent Flight Battery
Capacity
4480 mAh
Voltage
15.2 V
Battery Type
LiPo 4S
Energy
68 Wh
Net Weight
365 g
Max Flight Time
Approximately 23 minutes
-10°C to 40°C
Max Charging Power
100 W
App / Live View
Mobile App
DJI Pilot
EIRP
100mW
Live View Working Frequency
2.4GHz ISM
Live View Quality
720P @ 30fps (depending on conditions and mobile device)
Latency
220ms (depending on conditions and mobile device)
Required Operating Systems
  • iOS 8.0 or later
  • Android 4.1.2 or later
Recommended Devices
  • iOS: iPhone 5s, iPhone 6, iPhone 6 Plus, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, and iPad mini 3 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, and iPhone 6 Plus
  • Android: Samsung S5, Note 3, Sony Z3 EXPERIA, Google Nexus 7 II, Google Nexus 9, Mi 3, Nubia Z7 mini
  • *Support for additional Android devices available as testing and development continues
Wonder what the difference is?
Rated Power
  • 100 W
Phantom 3 Advanced
  • 57 W
Rated Power
  • 100 W
Phantom 3 Advanced
  • 57 W
Faster or reduced charge time with a 100W vs. a 57W
Hello my fellow Finnish man (Finnish too :) ), when I ordered p2v+ from DJI the tax and customs was included in the price to Sweden, should be the same for Finland. When u buy from DJI in Europe the phantom is sent from UK, at least mine was, so for those in UK the price includes vat and customs too and those might differ between countries.
Mine came straight from Hong Kong when I ordered it in May.
Bit the truth is that for us European it cost 1400€ instead of 1100€ like 1259$ should be. That's crazy.
Moving both video and control down to the 2.4ghz band is a good move. That 5.8ghz band isn't cluttered but it doesn't have as much punch. The move should give more range and I see they are saying 2000m vs the current 500m. Hopefully they can get both control and video to share the spectrum without causing too many issues.
. Btw, they did not say this, but it looks like the same batteries as what we have now.
I think the P2 is 11.1 Volts .... P3 is 15V ......they did say more powerful motors use less power and the way things are changing today more can be done with less power ....
Setag
