Hi All... I found a great valley in North Wales (U.K.) that had a hidden water fall at the bottom of the valley.It was a very deep valley and had very steep sides to it,with a lot of trees on one side and a rocky side on the other.MY first thought was to try to gain access to the bottom of the valley with my drone in a new 'backpack'. This decent proved to be VERY dodgy to say the least. but after some time and effort I finally reached to bottom.Now the only place I could find to settle was a small grassy outcrop right by the second of at least 3 of the water falls I knew of.
I unpacked the drone and fired up the I Pad 4 then the drone.NOW the first thing I found out was that because I could NOT received an mobile signal (02) then the 'map' in the corner of the screen was just 'grey' although it would show a 'home' position.WOULD it have been 'safe' to fly the drone without the full map showing the exact area ??? I thought not and decided to abort the attempt to fly...I was hoping to have been able to fly the drone in clear line of sight up from the start of the river then up stream and video all the water fall's although this would have meant that in some places I would not has clear sight of the drone and I would have had to use the video feed from the I pad alone (something that I am not used to doing 'yet').
Anyway after packing the drone away (or so I thought !) I spent a long time clambering back up the side of the hill back to the car and just before I reached the car I passed my backpack over a wire fence only to see one of the 3 'NEW' Battery's (1 was still in the drone) fall out and to my horror when I looked into the top pouch ( THE very same one I had forgot to ZIP UP ) that the other 'NEW' (had not even flown with it) was missing . SO I put the backpack into the car and then had the re-trace my step's back down the hill I went down and up and hoped to be able to find the missing battery.I got ALL the way down to the bottom to that grassy outcrop were I spotted the missing battery about a foot away from the edge,If it had fallen over that I would have never found it and could well have gone into the water to meet it's watery grave....SO I hope this heeds a warning to other's in making sure your bag is completely zipped up...That only left the long climb back up that hill...I know that at 57 I am not as fit as I used to be (too many ***'s don't help either)...
Sorry this story may be a little long !! But after looking at a way of getting this sort of 'shot' the only other way I thought of doing it was to fly from the top of the valley and down into it from above then turning the drone around and following the river back up-stream and getting a shot of those illusive water falls...BUT this would all have to be done by using the video feed on the i-pad screen only as I would have NO view of the drone itself...WOULD you take that risk ??? As I am still VERY new to all this I feel that I need more practice and flying 'blind' other than what I could see on the screen before I could feel confident to tackle such a challenge like this..What do you think ? The other issue I had to bear in mind is that 'if' something was to go wrong could I have found a safe place to land and then how would I have recovered my drone...ALL in all a bit too scary for me at the moment but hopefully I could find a way of doing it in the future...Happy flying and keep it safe...
