Would this device block GPS signal?
To be fair, your hand is a lot different than plastic (e.g. it has water in it)...
Well I guess to test this theory you could put a phantom battery on top of the quad to see if it blocks GPS signals.
thats a crap thing to do being that you dont own one. GPS's in phones are covered by the plastic/glass/metal case and work just fine. My P3 picks up a GPS signal in my basement and therefore covered by my house. I dont understand the negativity unless you own and can honestly review it.
I added a " proceed with caution" comment on this. Wow.
Anyway... way back last fall I wasn't happy with the time it took to get my satellites even after the re-route GPS cable mod, just for fun I took my dremel out and ground away at the plastic in the inside center of the plastic top. I ground away that little circle in the middle and part of the perpendicular branches that led away from it. I also ground a layer off the plastic lid itself right in the middle. Afterwards, I did seem to get my satellites quicker. I can't give it a fair comparison test though...
The primary GPS in my boat sits on the helm surrounded by several displays and a bunch of wires. Under a fiberglass top with some wires running through it. Works fine.
The third / fourth generation GPS systems are frigging incredible. My iPhone is currently registering a valid GPS lock on the ground floor of my house, three feet from the window. A few LEDs are unlikely to make a difference. Also realize that the GPS constellation isn't always 'up' in relationship to the drone - it can be sideways and, at altitude, even below the craft. So stuff on 'top' may not make much of a difference.
Only thing that would effectively block the GPS signal on the Phantom would be aluminum foil (seen it on a tested.com Youtube page).
@9:56 seconds in
Good to know. I undid the product comment. I still however will not personally use any accessories that will mount on top of my phantom. Thanks for posting everyone.
Think about all the stuff a car gps signal goes through and the phantom3a/p and i'd assume 4 have access to more satellites iirc. Pretty unfair to write a negative review over an untested theory.....
well I can leave a review,
Satellites , Litchi, OH MY
after that post, I tested it,, 7-10 satellites vs 15-20 without it.
Also, flying around I will go from 7-10 average to 3 for a split second.
unacceptable, and during that litchi mission I ran, I was lucky I had signal to get it back.
I have that PP kit, have had it about a week and 4x long flights. No GPS problems, I have more of an issue with the way the kit actually fits. The lights the way they clip to the legs are for lack of a better description sub-optimal, and the cradle that fits on the top is just "meh". I could get the same value with some Planet Bike blinkies wire tied to the legs. It's going back.
Yes these do cause interference. I will refer to mine anyway. Without a doubt it caused interference on my phantom 3 advanced right down to having to fly it home with no gps. Maybe it depends on where you live and how many satellites are available but I won't be using them again. Under normal conditions I'm only pulling in mid to high teens for number of satellites
pillylee2
