WiFi Conn
I generally fly with controller linked directly to iPhone 8 but today tried to not use the cord and go WiFi.. I could not get a stable connection even after rebooot, re- linking( got the green light stable) but after entering the password was dropped as no connection. I can use the direct wire but would like to sometime use WiFi. Using latest DJI Go app update
Ph3 Pro/Adv do not have WiFi capability. You should probably select a correct forum to write.
If he uses cable connection - then he must have a Adv or Pro model. So he's in correct section.
To "mymgb" - its not possible to WiFi the Controller to Phone or Tablet with Pro or Adv.
You can only do that with the Standard. If you think about trying standard controller with your Pro / Adv - save your money - it will not work.
Nigel
