Wierd noise
My phantom3standards gimbal is making a clicking noise and the left and right movement motor isn't working possible diagnosis?
My old camera used to make a squeal sound but I replaced it and it's fine. How long have u been flying it and have u had any crashes or anything to effect the camera?
No it's a three axis gimbal
Yes, but none of them have a 360 degree range.
All 3 motors have fixed, hardware limited ranges of about 90 degrees, although the pitch motor is the only one which is actually set up to utilize nearly that entire range.
The roll motor utilizes maybe 30-40 degrees of motion and the yaw motor uses maybe 10-20 degrees, if that. In fact, the limited camera yaw is an oft discussed non-issue on DJI forums.
So for all intents and purposes, Pepino Grande is correct in his assessment that the camera (effectively) only moves "up and down" (AKA "pitch").
