- Joined
- Sep 20, 2016
- Messages
- 73
- Reaction score
- 26
- Age
- 58
This video was shot in 4K 30fps with a Phantom 4. Granted the lighting that day was not good (the original footage looked way darker than this - this is corrected footage using Davinci Resolve with most settings turned up considerably - but the detail is the same as the original footage.) However in both this and the original footage, the details in the beach ground and trees near the house are almost non-existent, it looks very blurry. My partner shot this video so I'm not sure the exact settings used.
This was a fly by with pan but it was done pretty slowly. An ND filter may have been used so maybe that's a contributor Here's the file info from the original footage.
Here's the actual original, uncorrected footage:
Here's the file info:
General
Complete name : D:\Temp\Downloads\DJI_0016flybywithPOI.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2014.02 (qt )
File size : 190 MiB
Duration : 26 s 860 ms
Overall bit rate mode : Variable
Overall bit rate : 59.2 Mb/s
Encoded date : UTC 2017-02-25 07:40:18
Tagged date : UTC 2017-02-25 07:40:18
Comment : 0.91.142M
©xyz : +47.406590-122.936082+13.800
©xsp : -2.10
©ysp : -3.20
©zsp : +0.00
©fpt : +12.30
©fyw : -119.70
©frl : -1.40
©gpt : -18.00
©gyw : -119.00
©grl : +0.00
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=8
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 59.2 Mb/s
Maximum bit rate : 60.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.238
Stream size : 189 MiB (100%)
Title : DJI.AVC
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
General
Format : MPEG-4
File size : 190 MiB
Comment : 0.91.142M
©xsp : -2.10
©ysp : -3.20
©zsp : +0.00
©fpt : +12.30
©fyw : -119.70
©frl : -1.40
©gpt : -18.00
©gyw : -119.00
©grl : +0.00
Video
Format : AVC
Codec ID : avc1
Color space : YUV
Bit depth : 8 bits
Title : DJI.AVC
Language : English
