Which channel/band? Need help!
Frome, UK
I have a black pear diversity monitor and immersion 600.
I get confused on how to select/match channels and bands?
I really need help so I can get past the noisey screen.
I've had it work before but I think it was random luck!
Some picks here may help.
Thanks
Immersion uses band F so you need to set the diversity option to that. You can then let it scan for the channel within that band that the Immersion Tx is broadcasting on, or you can set it manually after determining the channel by the position of the little dipswitches on the transmitter (top right of the board in your pic).
Ok thanks
Those switches say of of on. So what does that mean?
Tried it on band F and tried every conceivable channel and nothing at all? I've got an awful feeling the immersion is fried?? But I'm careful of powering up and checking the antenna is on? Scratching my head???
Solved. Loose video wire inside:)
Starbase
