What is the difference between a Phantom 1 and Phantom 2?
Re: What is the difference between a Phantom 1 and Phantom 2
you need to have the phantom with the CW/CCW motors. If you have two black nuts and two silver nuts, you can use vision/p2 props. if you have the nuts that all screw off the same way, you will need to change two of your motors.
then you can get the OEM DJI vision props. ebay has them.
larger. push more air. the shape. more efficient.
